Inventor Forum
How do you create a plane tangent to 2 cylinders?
7 REPLIES 7
Message 1 of 8
mlandon
2041 Views, 7 Replies
I have 2 different diameter cylinders and I would like to create a plane that is tangent to both.
7 REPLIES 7
Message 2 of 8
cbenner
in reply to: mlandon
Probably more than one right way... but what I did was to create a sketch on the face of one of the cylinders, project geometry both cylinder OD's.  Then sketch a construction line tangent to both cylinders.  Finish Sketch.  Now create a plane by selecting the sketched construction line.  As below:
Like I said, there may be a better way to do this, but this seemed to work and was fairly easy.
Message 3 of 8
SBix26
In a part file (.ipt) or in an assembly file (.iam)?
Message 4 of 8
luiww
I have attached one way to create a tangent across 2 cylinders.
Used IV 2012
Message 5 of 8
mlandon
in reply to: SBix26
Sam, Sorry about that, it is in an assembly (.iam) Mike
Message 6 of 8
JDMather
Attach your assembly here.
Message 7 of 8
LT.Rusty
Here you go.
In an assembly, just create the work plane from any other plane or geometry you have available, delete any constraints that were automatically created, and then set new constraints to make it tangent to your cylinders.
Rusty
Message 8 of 8
mlandon
in reply to: LT.Rusty
Thanks for the info. I never thought to constrain the plane.
