Inventor Forum
How do I find Dimension Over rides in idw
2 REPLIES 2
stevec781
287 Views, 2 Replies
I have some drawings with lots of dimensions.  Is there a way to check if any have been over ridden or a global way to set all dimensions to model value?
Steve
2 REPLIES 2
scottmoyse
in reply to: stevec781
This should do it  for you:
http://inventortrenches.blogspot.co.nz/2011/06/using-ilogic-to-find-dimension.html
Scott Moyse
Design & Manufacturing Technical Services Manager at Cadpro New Zealand
Co-founder of the Grumpy Sloth full aluminium billet mechanical keyboard project
Hi stevec781,
The iLogic snippet that ScottMoyse refered to was originaly written to be used as part of a larger task, and although it will work to do what you ask, there actually is a built in solution for this as well:
  • Hold the Shift key and then Right-Click
  • Then choose Select All Overidden Dimensions from the menu.
I hope this helps.
Curtis
