I have some drawings with lots of dimensions. Is there a way to check if any have been over ridden or a global way to set all dimensions to model value?
Steve
This should do it for you:
http://inventortrenches.blogspot.co.nz/2011/06/using-ilogic-to-find-dimension.html
Scott Moyse
Design & Manufacturing Technical Services Manager at Cadpro New Zealand
Co-founder of the Grumpy Sloth full aluminium billet mechanical keyboard project
Hi stevec781,
The iLogic snippet that ScottMoyse refered to was originaly written to be used as part of a larger task, and although it will work to do what you ask, there actually is a built in solution for this as well:
I hope this helps.
Curtis
