Hello Guys,
I am modelling plain Bearing but i have problem getting holes at an angles. I have attached an image for it.
Holes are located on top side of the bearing.
Solved by torbjorn. Go to Solution.
Attach the ipt file here of what you have attempted so far.
There might be simpler ways, but if I understand this correctly, maybe you could use some like the enclosed (IV2011)? You will need to change some dimensions, since some are lacking and others seems strange in your drawing?
