Needing Help on how to add a tab on the ribbon bar, my computer has it but not sure how to add it to anothe. The Tab I'm looking to add is called: Add-Ins, see attached
Neil,
RC on the ribbon and select
Then find it in the next dialog window and slide it over to the right side.
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!! :smileyvery-happy:
