Inventor General
Member
Message 1 of 5 (294 Views)
FATAL REALDWG ERROR
294 Views, 4 Replies
03-08-2013 12:43 AM
Hi!!!
I am working with Autodesk Inventor and we are facing some problems, as Inventor reports as an Error and we lose all the information we haven't saved till then; and most of the times we have this problem when we click the save button.
It says that it's imposible to overwrite the file to Undu(The disk might be full)
I would very much appreciate if you could help me
Thanks!!
Pablo
*Expert Elite*
cbenner
Message 2 of 5 (249 Views)
Re: FATAL REALDWG ERROR
03-08-2013 04:22 AM in reply to: power1985
I would first have your IT people check to see if you are actually running out of disk space.  Inventor writes an Undo file to local disk space, saving information so that you can perform the Undo function.  The size of the Undo file can be set or changed in: Options, on the General tab.  The larger the Undo file, the farther back you can Undo things.
ChrisB
Please use Mark Solutions!.Accept as Solution &Give Kudos!Kudos to further enhance the value of these forums. Thank you! :smileyhappy:
http://cbennertipstricks.blogspot.com/
Member
Message 3 of 5 (244 Views)
03-08-2013 04:40 AM in reply to: power1985
First of all, I would like to thank you for the answer.
We work with a Server that has free space, and we are having the same problem in different work stations, but just in one .dwg. We have tried coping it in windows, use the pack and go appliction of Autodesk and use the new dwg, but this error keeps crashing us.
During the morning, we have also tried to enlarge the undo File, but we haven't been able to avoid the error.
We are thinking on starting the dwg again, because we must change every little change we make or we will lose everything.
Pablo
*Expert Elite*
cbenner
Message 4 of 5 (225 Views)
03-08-2013 07:27 AM in reply to: power1985
Yes, based on that it sounds like the drawing file itself is somehow corrupted.  Hard to say for sure of course, but it sounds like it is not hardware based.
ChrisB
Member
Message 5 of 5 (199 Views)
03-11-2013 12:33 AM in reply to: cbenner
Thanks!!! Will do the .dwg, again when we have time
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
