Is there an option in Inventor 2012 to preset BOM columns? So I don`t have to import xls file with preset columns every time I want to export BOM in Excel format?
Thank you,
Alex.
Solved by Curtis_Waguespack. Go to Solution.
Hi achmidt,
Have you tried setting up the assembly columns to your liking in your template, and then saving the template to keep those changes ( I button > Save As > Save Copy As Template)?
http://help.autodesk.com/view/INVNTOR/2014/ENU/?guid=GUID-AE6D085E-4324-4D9D-8941-12A500448064
I think this is what you're looking for.
I hope this helps.
Curtis
