Inventor General
New Member
Message 1 of 3 (799 Views)
Accepted Solution
Equation for catenary curve
799 Views, 2 Replies
01-28-2013 05:57 AM
I am designing a part that has the shape of a catenary. In order to make it right the first time, I want to shape the catenary af the exact equation and not by making a spline between points.
I am not a math genius nor an Inventor genius, so I someone could tell me the input (see attachment) I would be pleased!
The equation I need to draw (metric) is this: f(x) = -(2.0272/2)*(e^(x/2.0272)+e^(-x/2.0272))
The part is 3800mm wide and 2200mm high (see attachment 2)
I am looking forward to your suggestions!
*Expert Elite*
karthur1
Message 2 of 3 (745 Views)
Re: Equation for catenary curve
01-28-2013 12:03 PM in reply to: ehaubjerg
I could not get this to look exactly like your picture. I think my equation is correct.  Here is what I used for the equations.  Set your units to Meters.
x(t) = t
yt) = -1.0136 ul * ( pow(2.71828 ul;( t / 2.0272 ul )) + pow(2.71828 ul;( -t / 2.0272 ul )))
tmin = -1.9   tMax = 1.9
Here is what this looks like.  Maybe you can tweak it and get it to work. If I get some more time, I will also look at this again.
New Member
Message 3 of 3 (694 Views)
01-29-2013 02:39 AM in reply to: karthur1
Hi again.
Thank you very much for your reply. I worked out perfect. I am sorry, however, to tell you that I provided you the wrong equation - no wonder that you had trouble getting it right. The correct equation is f(x)= -(1063.35/2)*(e^(x/1063.35)+e^(-x/1063.35))
Sorry for that. However, I simply change the 2.0272 with 1063.35 and there it was!
You saved my day!
BR,
Esben
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
