Inventor General
projektant
Message 1 of 2 (121 Views)
Embedded Excel file in DWG
121 Views, 1 Replies
11-14-2012 03:52 AM
When inserting object - xls file, i found trouble, max. number of column i see in dwg file is 22.
What's wrong ?
Creating table using table - general require long time for set up every column (different with)
Product Support
Message 2 of 2 (92 Views)
Re: Embedded Excel file in DWG
11-15-2012 11:21 PM in reply to: projektant
This is known issue for Microsoft about "Insert Object". For Inventor, we have known this defect and submit a ticket to Microsoft and wait it could be fixed. By now it you want to insert excel file with much more column, could you split it at excel, then insert them twice into Inventor.
Yong Jing
Product Support Specialist
Frontline Technical Support, CSS. GCSO
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
