Inventor General
New Member
Message 1 of 5 (285 Views)
Drawing Disappeared, need help to recover.
285 Views, 4 Replies
12-07-2012 04:01 AM
Hi there,
I'm a Graphics teacher and my students have been drawing object for their end of year projects on Inventor 11, one of the boys was drawing and then his work disappeared. It's all still in the side panel so its still there, but the Zoom All tool does nothing and all of the objects visibilty is on as well. Its stumped all of the teachers here and its probably really simple as well, any suggestions?
I've attached the drawing if that helps?
Sam
cbenner
Message 2 of 5 (284 Views)
Re: Drawing Disappeared, need help to recover.
12-07-2012 04:23 AM in reply to: samueldhyams
First, this is a model not a drawing...
It appears that there is something radically wrong with sketch 16 at the bottom of the model tree.  Deleting this sketch brought the model back into visibility.  There is a parameter, d92 associated with that sketch which has a very strange value, see attached.
Not sure what the intent was since I can't get the sketch to show up.  however, deleting this sketch seems to repair the model.
ChrisB
Please use Mark Solutions!.Accept as Solution &Give Kudos!Kudos to further enhance the value of these forums. Thank you! :smileyhappy:
http://cbennertipstricks.blogspot.com/
New Member
Message 3 of 5 (207 Views)
model disappeared in assembly
01-31-2013 11:57 AM in reply to: samueldhyams
I'm having a similar issue and am wondering if someone can hekp me out.  I used the orbit command and the entire assembly disappeared.  However, when I double clicked on a sub-assembly in the browser, the sub-assembly would appear but when I double clicked the entire assembly in the browser, the entire assembly disappears again.  I checked the model paramters and everything looks OK. Very fustrating.
blair
Message 4 of 5 (191 Views)
Re: model disappeared in assembly
01-31-2013 10:53 PM in reply to: sarah.chan
System specs, sounds more like a hardware issue. Does selecting the home icon bring it back?
IV2015 PDSU / Sim Mech 2015 /
Win7-64
EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
Nvidia GTX-690 Classified - 335.23
SpacePilot Pro 3.17.7, 6.17., 4.11
New Member
Message 5 of 5 (182 Views)
02-01-2013 08:05 AM in reply to: blair
Not in this case.
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
