Inventor Forum
Display Appearance Settings
4 REPLIES 4
Matthewp10
1323 Views, 4 Replies
I am looking to change visual style default to Shaded with edge's however when i go about changing it in Aplication options - Display tab - appearance settings, i am stopped with a message as found in attached image. Please help.
4 REPLIES 4
-niels-
in reply to: Matthewp10
Welcome to the Forum!
As the message states, your current default is controlled by the document settings.
You can either set it to use the application options and have it use those in each document (more of an override.), or you'll have to change the document settings in your template.
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
Matthewp10
Good day and thank you for the warm reception.
ok this explains a lot, how would i go about changing my document settings in my template?
Thank you for the timeously reply
-niels-
Open your template
Go to Tools > Document settings (should be next to the application options.)
On the main tab (standards) click on the button "settings..."
In the window that pops up you can set the visual style to what you want it to be.
Hit OK on all the boxes to accept the change and save your template.
That should do it, you'll have to repeat for every relevant template.
(sheet metal, part, assembly.)
Hope this helps.
Niels van der Veer
The Netherlands
Matthewp10
in reply to: -niels-
Thank you 🙂
