Inventor General
MDS-MQ
Message 1 of 7 (350 Views)
Dimension Lines not visible
350 Views, 6 Replies
12-27-2012 08:45 AM
We resently upgraded to Inventor 2013 and since then we have been having an issue of dimension and leader lines being hidden under a text box or some other drawing entity.
This is very confusing since the text box does not have a white out associated with it, nore is there a way to put the test box to the back and dimension lines to the front...
It seems like our puppet masters that program this amassing tool where up to something and didn't quite get there.
IT sure would be nice (or an absolute requirement) that this gets fixed so I don't have to learn new hoops to jump through to get a quality drawing out of Inventor.
Mike
Employee
jan.miskanin
Message 2 of 7 (303 Views)
Re: Dimension Lines not visible
01-07-2013 02:01 AM in reply to: MDS-MQ
Hi Mike,
In Inv 2013, there was introduced clipping of geometry under the bounding box of text. This behavior is as designed.
You can try to change size of bounding box for text to minimum and manually update view, minimum/none geometry will be clipped.
Jan
MDS-MQ
Message 3 of 7 (285 Views)
01-07-2013 05:44 AM in reply to: jan.miskanin
Hi Jan
Thanks for the response. Too bad it was totally wrong.
I just installed SP 1.1 and the text box dose not hide any lines.
If this was done by design it was done poorly. It would be a nice option if there where a switch to turn on and off the white out and the white out removed all geometry not just dimension lines.
Oh, and when I shrinck my text box the test does a word wrap instead of staying in it's current location like you are showing.
Employee
jan.miskanin
Message 4 of 7 (277 Views)
01-07-2013 06:40 AM in reply to: MDS-MQ
Hi Mike,
Do you have updated views in SP1.1?
About the switch, I will talk to developers about your request. Thanks for your contribution.
About wrapping of text, use smallest boundary box possible (smaller then first part of the text).
Jan
MDS-MQ
Message 5 of 7 (268 Views)
01-07-2013 10:31 AM in reply to: MDS-MQ
Unfortunatly I spoke to soon in my last response. The dimension lines are still being removed by the text box. This is a terable feature. I am the one who desides what is getting blanked out on my drawing. Not some programer who has not produced a drawing in quite a number of years by the way this software has been developed.
Resizing the text box so that it is smaller then the smallest charactor is not a good solution since it makes it very difficult to layout an sort of sturcture in a test box that is not the size you want to work with on yuor drawing.
Attached is an example of what you are asking us to work with. Un-F_______ beleavable!
Active Member
Message 6 of 7 (212 Views)
02-07-2013 06:14 AM in reply to: jan.miskanin
This issue also applys to the boundaries of text boxes clipping hatching as I described here.
While the work-around of reducing the boundary box to be narrower than 1 character works, this issue is totally unacceptable and needs be properly addressed.
I am not sure why you would intentionally design this behavior to clip important geometry for the sake of "white space" in a text box. At a minimum I think you need to give the user the ability to control which item is "on top"- either the text box or the surrounding geometry. Another option is to give the user the ability to turn the "fill" of the text box on/off and thus control rather or not the text box clips surrounding geometry.
To me, this seems to be a pretty important feature.
Active Member
Message 7 of 7 (96 Views)
12-12-2013 11:22 AM in reply to: jcstevens
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
