I want to deselect the "Show Get Started Tab" in the Help drop down menu; I don't want the "Get Started Tab" to show in the ribbon. But, I can't; it is watermarked (greyed out) in all environments.
How can I do this in Inventor 2012?
Thanks for your help.
Hi material_31,
Appreciate your report this and it is a known issue in Inventor 2012 SP1, I had logged it in our issue tracking database (DID1420017) and I have confirmed that it has been fixed by our development team in our latest internal build. So this problem should be gone in the next release or next 2012 service pack.
Kevin Li
SQA Engineer
Autodesk, Inc.
Two possible workarounds to not see the command are:
1. Move the command to the expanded panel.
2. Do not display the “Learn about Inventor” panel in its entirety by unchecking the “Learn about Inventor” context menu.
Result :
