Inventor General
Message 1 of 8 (202 Views)
Constraining on a revolved Part
202 Views, 7 Replies
01-24-2013 04:17 AM
Hi all,
I'm really struggling with constraining a welment assemly. I've attached a JPG of the Assembly to give some idea as to what I want to do, but I cant get the constrains to go where I want them.
Basically this assembly is a wheel with three equally spaced stays welded to a large nut hub. I have constrained the centre axis of the wheel to the centre axxis of the Nut so the wheel and nut will remain aligned.
What I'm struggling with is constraining the three stays to the wheel and to the nut equally spaced around the nut.
Any help here would be great
Cheers
Message 2 of 8 (200 Views)
Re: Constraining on a revolved Part
01-24-2013 04:36 AM in reply to: jeddell
I would use a workplane Mate-Flush constraint for the first one and then Pattern Component the other two.
Attach your assembly here if you can't figure it out.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2014 Edu 64-bit
Message 3 of 8 (150 Views)
01-25-2013 09:04 PM in reply to: JDMather
Sorry, I tried to constrain as you suggested, but there are too many other variables that didnt get explained. Junior operator here so some clearer explanations really are needed.
I've attached the assembly and parts, so you can show me what you mean
Thanks for trying
Cheers
Message 4 of 8 (140 Views)
01-26-2013 05:52 AM in reply to: jeddell
Looking at your parts I'm not convinced that you have the best angles on the Wheel Stays.
Can you make changes to this part or must it be as you have designed?
I would do this as multi-body solids and then push out the individual parts if you have trouble lining up the desired angles.
Also, never use zero (0) value dimensions - use coincident constraints instead.
An ACME thread should be 29° an angle of 28.6708708 is not manufacturable.
WorkAxis1 in the hub is a duplication of the Y Axis and therefore not needed.
If I get a chance I will model up an example of how I might do this.
You created a workplane in the assembly - don't need this - use the existing part workplanes.
The thread has thin sliver face ends - I would chamfer before cutting thread - just like real world machining operations.
Message 5 of 8 (109 Views)
01-26-2013 05:46 PM in reply to: JDMather
Thanks for your reply and review of the parts. I do appreciate some expert feedback.
To answer you comments:
Yes, I can make changes to the Stays, I'm duplicating an old technical drawing whcih does not show the ends, but the entire part. The drawing olny shows the weld type aa a fillet around the ends of the stays
Not sure what you mean by Zero value dimensions. Can you elaborate on this one?
I used the dimensions from an ACME thread table. You're right, I should have dimensioned the angle to 29 Degrees.
Point atken on the work axis, Still getting my head around how to select the correct axis fo revolve. Gettin there!
Not sure what part workplanes I should use to constratin these parts. The angle on the hub is a chamfer. When I try to constrain to it, it picks the axis instead. Which is one of the things I'm struggling with
I look forward to your example
Cheers
Message 6 of 8 (98 Views)
01-27-2013 08:05 AM in reply to: jeddell
I haven't used a Zero dimension since leaving Mechanical Desktop back in '02.
Use Coincident Constraint.
Message 7 of 8 (82 Views)
01-27-2013 02:43 PM in reply to: JDMather
AH! OK got it.
I di start that sketch inside the model, but I didn't know how to get the coil to extend past the hub nut. I figured this was the easiest solution.
Obviously its another contraint process. Seems to be my weak point
cheers
Message 8 of 8 (76 Views)
01-27-2013 03:15 PM in reply to: jeddell
cheers
Project Geometry and Coincident Constraints will become your strongest points (for Inventor sketching).
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
