Inventor Forum
Collision Detection And Drive Constraints
7 REPLIES 7
Message 1 of 8
1063 Views, 7 Replies
Hi
   Assemble several parts from Solidworks  through step profile.Part2 and part3(attachments) no static interference ,when driving constraints (driver) immediately a collision report appears.Additional,when restrain the part 3(attachments)and drive constraint(driver) meanwhile open the collision detection ,finally,part2(attachments) goes through the barrier no checking collision.
   Thanks in advance.
Tags (1)
7 REPLIES 7
Message 2 of 8
CCarreiras
Hi!
What?!!
Try to attach the files here.
Did you find this reply helpful ? If so, use the  Mark Solutions!  Accept as Solution or Give Kudos!Kudos - Thank you!
CCarreiras
Message 3 of 8
mcgyvr
in reply to: CCarreiras
Doodle foodle schmoodle oobly bo do ti ta flakn smackn.. (attached) Smiley Very Happy
Message 4 of 8
gsmith9810
It sounds like you need to better understand the use of CONTACT SETS. It is also possible that the imported models have fasteners with an OD greater than the modeled ID of the threaded hole. This condition used to produce an immediate interference report.
Gary Smith
Inventor Product Design Suite 2013sp2
Windows 7sp1 64-bit
nVidia Quadro 2000
Message 5 of 8
Hi!
thanks!
Message 6 of 8
Message 7 of 8
in reply to: gsmith9810
Thanks! I will try again!
Message 8 of 8
Hi!
sometimes, it moves for a while then produces a report! Additional,it's not contact sets!
