A really nice upgrade for inventor would be to move the check boxes in the settings dialog to the main Check in dialog window.
Solved by Cadmanto. Go to Solution.
Solved by cbenner. Go to Solution.
http://forums.autodesk.com/t5/Inventor-IdeaStation/idb-p/v1232
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
I would also add that if you do post an idea as per Chris's suggestion, make sure you not only post a link in the idea to this thread, but post the idea link back here in this thread.
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
