Am looking for the feasiblity to check space available in Segment.
I've assigned a segment diameter as 2 mm, and i have 2 wires have .9 mm dia each, Now i want to know what will bw the remaining space available in the segment.
in another way around, if am adding more wires in the segment will inventor give any error message stating that there is no space for route more wires in that segmant,
Can any one help me to resolve thi.
Regards
Manikanda Prabhu
The answer is no (sort of).. Inventor does not calculate this for you. But the size of the segment does grow based on the wires routed through it..
Just use the measure tool to see the diameter of the segment after you route your wires then measure the diameter of the individual wires and you can see how Inventor is changing the segment size based on wires routed into it.
