Inventor General
Member
Message 1 of 5 (305 Views)
Accepted Solution
Cant extrude in assemble drawing
305 Views, 4 Replies
04-04-2013 11:51 AM
Can’t extrude in assemble drawing in inventor when I draw a sketch and finish sketch
And try to extrude the sketch it extrudes but only in cut mode  it is the only button that is working the rest are all faded out
*Expert Elite*
Curtis_Waguespack
Message 2 of 5 (303 Views)
Re: Cant extrude in assemble drawing
04-04-2013 11:53 AM in reply to: 1207463
Hi 1207463,
This is called an Assembly Feature. And that is just the way it works, you're only able to mill/remove material from the assembly level, if you need to add material just edit the part and create the sketch in that part.
The reason behind this goes something like this: Imagine we have a part that we make and stock in inventory, but in some assemblies we add a hole and a kerf notch to the part. We don't want these modifications in every place the part is used, so placing the feature at the assembly level let's us have this flexibility.
Also just as a tip, you might want to use the words "assembly file" rather than "assembly drawing". Typically in Inventor assembly drawing refers to a drawing file (IDW or DWG) that details an assembly. Same goes for "part file" vs. "part drawing".Just a minor point, but it helps make your questions easier to understand.
I hope this helps.
Curtis
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
*Expert Elite*
Cadmanto
Message 3 of 5 (291 Views)
04-04-2013 12:04 PM in reply to: 1207463
Your best bet would be to RC on the part in the assembly browser and edit it within the assembly to add the protruded feature you need.
A specially if you are trying to create or do top down engineering.
check.PNGIf this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! :smileyvery-happy:
Best Regards,
Scott McFadden
Inventor Professional 2014
(Colossians 3:23-25)
Member
Message 4 of 5 (268 Views)
Re: Can't extrude in assemble drawing
04-04-2013 01:00 PM in reply to: Curtis_Waguespack
Thanks managed to work it out was doing it **** from elbow create sketch then create part on sketch
*Expert Elite*
Cadmanto
Message 5 of 5 (260 Views)
04-04-2013 01:15 PM in reply to: 1207463
Marking this thread as solved and what exactly helped you would help others in the future with similar issues.
Best Regards,
Scott McFadden
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
