Inventor General
Distinguished Contributor
Message 1 of 4 (265 Views)
Accepted Solution
Can anyone explain the balloon shape "Circular with 2 entities"
265 Views, 3 Replies
03-01-2013 12:21 PM
I'm trying to figure out what the additional number in the balloon option "circular w/ 2 entities" represents.
*Expert Elite*
Curtis_Waguespack
Message 2 of 4 (258 Views)
Re: Can anyone explain the balloon shape "Circular with 2 entities"
03-01-2013 12:29 PM in reply to: jpblower
HI jpblower,
By default this displays the Item number on top, then the QTY, but you can edit the balloon style to change which one displays on top, or to use different  iProperties.
I hope this helps.
Curtis
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
Message 3 of 4 (246 Views)
03-01-2013 12:54 PM in reply to: jpblower
Thanks.  Is there anyway to override the second number?  I can override the item number but nothing else.
Active Member
Message 4 of 4 (229 Views)
03-01-2013 01:23 PM in reply to: jpblower
Not an expert by any means but I did do this the other day.  Go into the BOM  and create a phantom part.  Yhen you can edit the balloon to use the phantom part data
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
