Can anyone help with the attached part? I need to create a flat pattern for this part, but it gives the error "Could not build this FlatPattern : Bend geometry passes through the bend axis.
Tabitha
Solved by johnsonshiue. Go to Solution.
When requesting help and posting parts, it is always a good idea to include what version of the software you are using.
Not everyone is using the latest version of Inventor and cannot open parts made with a newer release.
Hi! Corner13 and Corner15 seem to make the sheet metal part fail to unfold. There faces merged becaused of the corners. Could you take a look?
Thanks!
Thanks everybody for the help! I was able to change the angle on the two cuts at Corners 13 and 15 and that solved the problem.
