Hi all,
One doubt mine that I don't know why but I posted on 2014 Wish list, so, here it is again :).
About Substitute Shrinkwrap parts, it doesnt automatic update when I use UPDATE or even REBUILD ALL inside the LOD with it, even if I dont break the link with the assembly it doesnt update, so I have to go in each assembly with Substitute parts ( with are many in huge projects) and then verify with "Check for updates" in the correct LOD (which in some cases are more than one per assembly). Is there a way to update them direct from the main assembly with rebuild all or something like that ?
Thanks again
Túlio Barata
Anyone got any idea about it ?
Right now I'm updating more then 80 parts as Shrink, thats a little trouble.
The way I've found, the easier, is user the WINDOWS Search in the projects folder looking for all files with a sulfix of _SUB-TYPE (2 types each Assy) and then open one by one and use check for updates.
If had any tool to make that easier, or a simple UPDATE in the master assembly to update all sub assemblies suistitutes..
Túlio Barata
