Inventor Forum
Automated assembly based on work geometry?
3 REPLIES 3
336 Views, 3 Replies
I'm trying to setup an assembly based on a complex 3D sketch.  In simplest terms, if I have a sketch for the perimeter of a house, I'd like to add instances of a 2x4.ipt at specified locations automatically.  That's not necessarily every 16", but rather wherever I put a specific geometry.  I'm imagining two work axis or sketch lines, one along the perimeter to determine the location of the 2x4 and one perpendicular to determine the direction the 2x4 points.  In actuality my sketch won't be a rectangle, but rather a complex 3D spline, that's why I'm hoping to get some sort of automated process.  And the current design involves somewhere on the order of 1500-1800 2x4s.  Making the sketches and geometry will be nightmarish enough, I'd prefer to be able to breeze through the assembly portion.
If that's unclear let me know and I'll try to sketch up what I'm talking about in more detail.
3 REPLIES 3
JDMather
Are you familiar with skeletal modeling and the Frame Generator?
Curve driven patterns?
in reply to: JDMather
I'm fairly used to skeletal modeling, but not Frame Generator or Curve Driven Patterns. I'll take a look around and start some learning! Thanks!
JDMather
For frame generator you will need to create you own custom 2x lumber profiles.
Use your skeleton file in the Frame Generator.
For curve driven patterns see this http://home.pct.edu/~jmather/skillsusa%20university.pdf
going beyond that - you might look for information on iLogic and iAssemblies.
