Inventor General
Distinguished Contributor
Message 1 of 3 (214 Views)
Accepted Solution
Autodesk 360 file - file locking across multiple locations
214 Views, 2 Replies
01-14-2013 12:29 PM
Does Autodesk 360 cloud storage work in any way shape or form similar to a Vault whereby users can check out, lock, and then check in designs? Can Vault be used in conjunction with Autodesk 360, or does Autodesk 360 eliminate or replace the need for Vault?
What's the best way for individuals working at multiple sites to work without overwriting each others' data or having save collisions?
*Expert Elite*
DarrenP
Message 2 of 3 (206 Views)
Re: Autodesk 360 file - file locking across multiple locations
01-14-2013 12:47 PM in reply to: dick_upton
Does Autodesk 360 cloud storage work in any way shape or form similar to a Vault whereby users can check out, lock, and then check in designs? no it doesn't work like vault
this isn't a replacement for vault
360 is not a file mangement system
its a file sharing tool its almost  like a ftp site
Message 3 of 3 (192 Views)
01-14-2013 04:14 PM in reply to: dick_upton
OK thanks.
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
