Inventor General
mehatfie
Message 1 of 4 (239 Views)
Access Application Options through iLogic
239 Views, 3 Replies
02-10-2012 07:34 AM
Hello All,
I am new to iLogic and trying to access the "Application Options" under the "Tools" tab. I am trying to grab some information from a couple of fields but it seems that I don't have the right coding or Snippets that indicate how I would do so.
Please point me in the right direction of a helpful source or if anybody knows how to code this.
Thanks in Advance
Mitch
*Expert Elite*
Curtis_Waguespack
Message 2 of 4 (232 Views)
Re: Access Application Options through iLogic
02-10-2012 08:06 AM in reply to: mehatfie
Hi mhatfield,
Here is a quick example of an iLogic rule that works with Application Options. If you look up SketchOptions or GeneralOptions, etc in the API reference, you'll find a listing of all of the properties available. Or reply back with the specific properties you're wanting to change.
I hope this helps.
Curtis
'get Application Options > General Tab > User Name
myName = ThisApplication.GeneralOptions.UserName
MessageBox.Show(myName, "Title")
'set Application Options > General Tab > 3D Indicatior
if ThisApplication.GeneralOptions.Show3DIndicator = True Then
ThisApplication.GeneralOptions.Show3DIndicator = False
Else if ThisApplication.GeneralOptions.Show3DIndicator = False Then
Else
End if
'get current Application Options > General Tab > Select Other Delay
myDelay  = ThisApplication.GeneralOptions.SelectOtherDelay
'set Application Options > General Tab > Select Other Delay
myDelay = InputBox("Enter a new Select Other Delay", "iLogic", myDelay)
ThisApplication.GeneralOptions.SelectOtherDelay = myDelay
'set current Application Options > Sketch Tab > Display Grid Lines
if ThisApplication.SketchOptions.DisplayGridLines = True Then
ThisApplication.SketchOptions.DisplayGridLines = False
Else if ThisApplication.SketchOptions.DisplayGridLines = False Then
Else
End if
'Update All
iLogicVb.UpdateWhenDone = True
'Display the Application Options Dialog Box
ThisApplication.CommandManager.ControlDefinitions.Item("AppApplicationOptionsCmd").Execute
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
mehatfie
Message 3 of 4 (227 Views)
02-10-2012 08:19 AM in reply to: Curtis_Waguespack
Hi Curtis,
Thank you very much for your assistance as just seeing the "walk through" as to how the code works will definitely help me moving forward.
Is there a possibility you'd be able to help me with my other issue?
http://forums.autodesk.com/t5/Autodesk-Inventor/Trigger-Custom-Add-Ins-Button-through-iLogic/td-p/33...
Again, Thank you for all your help
Mitch
Member
Message 4 of 4 (65 Views)
11-08-2013 02:13 AM in reply to: mehatfie
Is it possible to change the color scheme and bacground color with ilogic roles? Does anybody knows how to code this?
Arnstein
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
