Inventor Forum
2D iParts in Assemblies?
2 REPLIES 2
292 Views, 2 Replies
This is using Inventor 2013 Profesional.
I've created a simple iPart and want to insert multiple instances of it into an assembly. The plan is to use a parameter-driven iPart to create multiple variations on the same basic model which will eventually be lasercut.
I've included a sample archive. 2DiPart is a simple part with a couple parameters. 2Dassembly is where I've tried to include this part. I'm able to walk through all the dialogs to place the iPart, and will even see it in the canvas as I select the insertion point. However, after I dismiss the dialog, nothing shows up in the canvas. I'm still able to see the component instances in the project explorer however.
Am I missing a step here, or is this just not supported. I'm open to other suggestions as well about how to best to get multiple instances of a parametric iPart into a drawing that can be lasercut.
Dan
Tags (1)
2 REPLIES 2
LT.Rusty
Add an extrusion.
You'll still be able to put your parts into a drawing in 2D, but it appears that you need to have at least one actual feature for the iParts to appear in the assembly.
Rusty
in reply to: LT.Rusty
Thanks LT.Rusty that did the trick. Once the extrusion was added, I could add multiple versions of the iParts to the assembly and was able to proceed with creating a DWG and getting it into Corel for laser cutting.
