How do I configure the new "Inventor Home" to show the templates associated with my project file and not the default ones that ship with Inventor?
Solved by ChrisMitchell01. Go to Solution.
Solved by mdavis22569. Go to Solution.
mcgyvr,
Nothing has really changed for 2015 around defining template locations. MyHome will use what is referenced under the Templates section, of your current project. If that is set to Default then it will use the path as defined in Tools, App Options, File tab.
Note that MyHome does not currently support displaying sub-folders under the top level Templates folder, but File, New will still leverage those.
-Chris
@ChrisMitchell01 wrote:
mcgyvr,
-Chris
I shouldn't have even posted.. I knew what the answer was going to be..
Thats the problem.. "new" works just fine (as it has in the past) as I have all my templates in nice organized folders.. My home is just another half finished Autodesk function..
A "smart" move would have been to either make it work just like new does or that button for "configure default templates" should have been a file picker to pick each template that you want assigned to those new fancy icons..
Half ****.. would have been a nice/simple ease of access feature for "everyone" but oh well.. off to turn that junk "HOME" off.. Its absolutely 100% useless to me. </2015 rant#1>
The sub-folders will still work for creating new files, but unfortunately not from the MyHome page.
Fully agreed/achnowledged though - more work is planned around this for next release. All this came up during Beta testing activities, but there wasn't time/resourcing to cover everything for this specific project.
The New icons simply correspond to the files named "Standard.xxx". The drawing icon relates to either Standard.idw or Standard.dwg, as defined by your app option, Drawing tab setting for idw or dwg.
-Chris
-Chris
Well.. next time.. Shoot me an email.. I'll let you how it should be done
I think we are all sick of the Autodesk "rush" jobs and would rather you just hold off till next year.
I'd like to see a 1 time start-up splash screen too for "welcome to Inventor 2015... please make sure your project file is set below so we can proceed to automatically migrate all necessary files in the selected project file. Note this will include all templates and your style library as well as material and appearance libraries as referenced by your project file. Click next to begin."
Then it would give you a "migration complete" and you would be presented with the Home screen and all those part/assembly icons would be setup properly..
Man that sure would be nice.
We'll be previewing some new work for this in the next few weeks, as part of the Inventor Beta/Feedback project, (which you're already a member of); I'm sure you'll let us know what you think there
Chris
Hi i need help to figurate out the My Home in INventor 2015, it shows the last open model, assemblies ... but it seams that the list keeps growing and there is to stopping. how much files are keep on this list and if there is an option to clear up the list?
I believe the list will grow until it reaches 500 items before it starts overwriting the entries. In 2015 the only way to remove items from MyHome is to edit the registry & delete entries under HKEY_CURRENT_USER\Software\Autodesk\Inventor\RegistryVersion19.0\Recent File List
Hope this helps,
Chris
