2 Kudos
FarrenYoung
Level of Detail Support in Assemblies
Status: New Idea
by Mentor on ‎11-19-2012 02:22 PM
It would be extremely useful to have Level of Detail support in assemblies.  It's very common for customers to use levels of detail in their drawings and without this built in one either has to code their own mechanism to create the levels of detail or set the hidden parts rule on the drawing views to hide the components that they don't want.  The hiddenParts approach is slow and leaves the customer with a drawing different than what they would create manually.
Comments
by Active Contributor alundr on ‎01-10-2013 09:15 AM
LOD support and representation view support would be greatly helpful.  It would be helpful to be able to use the views to turn off parts if the user does not want to see the hidden lines.  Section and detail views are not  always sufficient.
You are not logged in.
IdeaStation Guidelines
Review guidelines and best practices
before posting a new idea
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
