Try editing your Reg file and adding a - between the [ and the text on each line like this
[-HKEY_CURRENT_USER
Then run the reg file. It should remove the registry entries.
Kent
Assistant Moderator
Autodesk Discussion Forum Moderator Program
"jat14" wrote in message news:f17bf95.1@WebX.maYIadrTaRb...
> Thank you that worked fine
> How can i get the addin out of the list of addins in inventor It still shows in the list
as unloaded
