iproperty in title block
2 REPLIES 2
ac69
830 Views, 2 Replies
Hi everyone,
I have a text box in the title block which displays the "part number" from drawing iproperties.
I need to change it to display the "part number" from model iproperties.
Will this be possible via VBA?
Thank you.
Tags (1)
2 REPLIES 2
Dennis.Ossadnik
in reply to: ac69
Hi ac69.
You can change the reference to model by editing the FormattedText of the text box. Here you have to replace Property Document="'drawing'" with Property Document="'model'"
Here you can find a litte example that works with our standard templates (English)
VBA example:
Sub ChangeReferenceInTitleBlock()
Dim oApp As Application
Set oApp = ThisApplication
Dim oDoc As DrawingDocument
Set oDoc = oapp.ActiveDocument
'Select the title block you want to edit
Dim oTitleB As TitleBlockDefinition
Set oTitleB = oDoc.TitleBlockDefinitions.Item(1)
'go to sketch edit mode
Dim oSketch As DrawingSketch
Call oTitleB.Edit(oSketch)
'Search for the correct text box
'replace "<PART NUMBER>" for the correct expression in the language you have installed Inventor
'this example shows the English version
'You can check the expression by opening your title block manually. -> Screenshot
Dim tempTB As TextBox
For Each tempTB In oSketch.TextBoxes
    If tempTB.Text = "<PART NUMBER>" Then 'see hint above
    'change reference from drawing to model
        tempTB.FormattedText = Replace(tempTB.FormattedText, "Property Document='drawing'", "Property Document='model'")
    End If
Next
'exit edit mode and save
Call oTitleB.ExitEdit(True)
End Sub
Here you can find the correct expression: Edit - Title block (f.e. German version)
I hope this will work for you.
Please click "Accept as Solution" if this response answers your question.
Dennis Ossadnik
Senior Technical Support Specialist
ac69
in reply to: Dennis.Ossadnik
Hi Dennis,
Thanks for the solution. It works well.
One more question: Is there any way to set the height of the text? Either to fit into the textbox either to give an actual value (5.5 for example).
I tried to use : "tempTB.FittedTextHeight() = True"
but it doesn't work. And unfortunatelly, there is no "tiptext" to help. Just an error message : "Wrong number of arguments or invalid property assignment".
