I have made a iPart and have gone through iLogic and applied a Form .
If I now place the iPart in a assy and edit the iPart the Form is not visible.
Is that not possible?
I happened to see your post and I'm not sure if you have got the answer. If you search iLogic & iPart, you could find lots of posts have explained that it was recommended to use iLogic in iPart factory.
In your scenario, when you place the ipart (factory) in assembly, indeed, it generated one ipart member and ilogic rules including form were lost.
I'm curious why you want to use iPart to do that, I saw your model, there is only one member, it seems normal part with your iLogic form is sufficient.
