FYI, I can answer my own here!
VB only allows data to be pulled from forms, not pushed to forms!
"Steve Anderson" wrote in message
news:9CD1082E8D9E181809C9B50D49345C0C@in.WebX.maYIadrTaRb...
> I have two forms. Each form has a textbox called txtMatlCode...
> The goal here is to click on a command button to get the material code
from
> a list. This is then populated locally. When Exiting the form, the
textbox
> on the other form is to be populated with the same information. THIS IS
> WHAT IS NOT HAPPENING. I have checked everything else with msgboxes, etc,
> and the local textbox is being populated correctly.
> This relatively simple thing is driving me crazy. Any ideas? And thanks
in
> advance for the help!
> Private Sub cmdMatlCode_Click()
> frmPartProp.Hide
> frmMatlSearch.Show
> End Sub
> Private Sub msgDataGrid_Click()
> Dim lcol As Integer
> R = msgDataGrid.Row
> For lcol = msgDataGrid.FixedCols To msgDataGrid.Cols - 1
> msgDataGrid.Col = lcol
> msgDataGrid.CellBackColor = &H80000002
> msgDataGrid.CellForeColor = &HFFFFFF
> Next lcol
> frmMatlSearch.txtMatlCode.Text = msgDataGrid.TextMatrix(R, 1)
> End Sub
> Private Sub cmdExit_Click()
> Dim MACODE As String
> MACODE = frmMatlSearch.txtMatlCode.Text
> frmPartProp.Show
> frmPartProp.txtMatlCode.Text = MACODE
> frmMatlSearch.Hide
> End Sub
