More than you need probably (and not cleaned up at all) but this is a
module I use to read info out of text file and apply the values to the
properties of an IDW:
Private Sub cmdApply_Click()
If cbGetFileInfo.Value = True Then
'this is the name of the project file...
'use it, strip off the ipj and replace by txt
strOpenName = ThisApplication.FileLocations.FileLocationsFile
strOpenName = Left$(strOpenName, Len(strOpenName) - 4) & ".txt"
On Error GoTo NoFileFound
If strOpenName <> "" Then
Open strOpenName For Input As #1
Line Input #1, tempstring
If tempstring <> "[WORK ORDER NUMBER]" Then
MsgBox "This is not a valid Project Info File"
Exit Sub
Else
Close #1
End If
'run thu file to record info
Do While (tempstring <> "***EOF***") And Not EOF(1)
If tempstring = "[WORK ORDER NUMBER]" Then
Line Input #1, WorkOrderNumber
If WorkOrderNumber = "*" Then
WorkOrderNumber = ""
End If
ElseIf tempstring = "[ASSET ID]" Then
Line Input #1, AssetID
If AssetID = "*" Then
AssetID = ""
End If
ElseIf tempstring = "[RA]" Then
Line Input #1, RA
If RA = "*" Then
RA = ""
End If
ElseIf tempstring = "[COST CENTER]" Then
Line Input #1, CC
If CC = "*" Then
CC = ""
End If
Else
End If
Loop
Close #1
Else
End If
'fill in the form values
tbProject.Value = AssetID
tbAuthority.Value = RA
tbCostcenter.Value = WorkOrderNumber
tbDept.Value = CC
End If
'assign variables to the values in the text boxes
'dont use the variables above directly as they are going to be used
elsewhere
Project = tbProject.Value
Comments = tbComments.Value
Authority = tbAuthority.Value
CostCenter = tbCostcenter.Value
Keyword = tbDept.Value
oPropsets.Item("{32853F0F-3444-11d1-9E93-0060B03C1CA6}").ItemByPropId(kProje
ctDesignTrackingProperties).Value = UCase(Project)
oPropsets.Item("{F29F85E0-4FF9-1068-AB91-08002B27B3D9}").ItemByPropId(kComme
ntsSummaryInformation).Value = UCase(Comments)
oPropsets.Item("{32853F0F-3444-11d1-9E93-0060B03C1CA6}").ItemByPropId(kCostC
enterDesignTrackingProperties).Value = UCase(CostCenter)
oPropsets.Item("{32853F0F-3444-11d1-9E93-0060B03C1CA6}").ItemByPropId(kAutho
rityDesignTrackingProperties).Value = UCase(Authority)
oPropsets.Item("{F29F85E0-4FF9-1068-AB91-08002B27B3D9}").ItemByPropId(kKeywo
rdsSummaryInformation).Value = UCase(Keyword)
tbProject.Value =
tbComments.Value =
tbAuthority.Value =
tbDept.Value =
Exit Sub
NoFileFound:
MsgBox ("The Project Information File Was Not Found")
End Sub
and the text file is formatted liek this:
[WORK ORDER NUMBER]
5512-45
[ASSET ID]
45144-78-78
[RA]
[COST CENTER]
12101
***EOF***
Sean Dotson, PE
http://www.sdotson.com
Check the Inventor FAQ for most common questions
www.sdotson.com/faq.html
"David Estabrooks" wrote in message
news:F61A3EE6DC90F2ABFDF0111ABD437FBF@in.WebX.maYIadrTaRb...
> Looking for way to pick up data from an external txt file and changing
text
> within idw. Job #, Customer name, qty etc
