Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Part iProperties from idw
2 REPLIES 2
nannerdw
543 Views, 2 Replies
Is there any way to add an "iProperties" item to the context menu in the drawing environment, so that I can select a part on the drawing and access its iProperties, instead of having to "Open, edit iProp, Close," for each individual part?
2 REPLIES 2
philippe.leefsma
in reply to: nannerdw
The context menu can be customized, see links below for examples. You will need to determine what is the active document (drawing or not) in order to decide to insert your custom entry or not and to which part belong the selected drawing curves if you want to display the correct iProperties.
http://adndevblog.typepad.com/manufacturing/2012/05/customizing-radialmarkingmenu-and-linearmarkingm...
http://modthemachine.typepad.com/my_weblog/2012/03/customizing-marking-menus.html
Philippe.
Philippe Leefsma
Developer Technical Services
Autodesk Developer Network
nmunro
An existing solution. www.ipropwiz.com
https://c3mcad.com
