Is there any way to add an "iProperties" item to the context menu in the drawing environment, so that I can select a part on the drawing and access its iProperties, instead of having to "Open, edit iProp, Close," for each individual part?
Solved by philippe.leefsma. Go to Solution.
The context menu can be customized, see links below for examples. You will need to determine what is the active document (drawing or not) in order to decide to insert your custom entry or not and to which part belong the selected drawing curves if you want to display the correct iProperties.
http://modthemachine.typepad.com/my_weblog/2012/03/customizing-marking-menus.html
Philippe.
