Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Opening an Assembly to update and save
4 REPLIES 4
251 Views, 4 Replies
I created a master excel spreadsheet to get around the i-assembly issue,
fake parts and excel driven/linked BOMs. (Thanks for the nice tuts Sean),
but now I have a problem working with the Inventor API.
My VB6 program updates a few spreadsheets, but now I need to update the
master assembly before opening the drawings for printing.
I've tried a few ways to open and update an assembly, but to no avail.
Private Sub Command1_Click()
Dim oAssyDoc As Inventor.AssemblyDocument
Set oAssyDoc = GetObject("J:\...\...\...\...\...\...\...\ASSY.iam")
oAssyDoc.Update
oAssyDoc.Save
oAssyDoc.Close
End Sub
Error: Run-time Error '7' - Out of Memory on the Second Line
I hate to ask for debug help...but what am I missing?
The file I'm opening is but 250k, but it has links to many parts that need
to update from the excel change.
Should there also be some reference to a project, or can I only use the
current project that Inventor was closed with?
-af
4 REPLIES 4
The problem is using the GetObject function to open the document. Replace
the call to GetObject with something like....
Dim myApp As Inventor.Application
Set myApp = GetObject(, "Inventor.Application")
myApp.Open "yourfile.iam", True
Set oAssyDoc = myApp.ActiveDocument
No error checking so be careful....
rw
"It's not the modeler mate, It's how you use it"
"A.Fickes" wrote in message
news:D8421E11EF14BF48430285E6F5F736BF@in.WebX.maYIadrTaRb...
> oAssyDoc.Update
> oAssyDoc.Save
> oAssyDoc.Close
> End Sub
> Thanks,
> -af
I input the code:
Dim InvApp As Inventor.Application
Set InvApp = GetObject(, "Inventor.Application")
InvApp.Open "J:\ASSY.iam", True
Set oAssyDoc = InvApp.ActiveDocument
oAssyDoc.Update
oAssyDoc.Save
oAssyDoc.Close
End Sub
but now I get the error on line 3
Run-time error '429'
ActiveX component can't create object
Am I missing Project References?
I am using:
Visual Basic For Applications
Visual Basic runtime objects and procedures
Visual Basic objects and procedures
OLE Automation
Autodesk Inventor Object Library
"Rob W." wrote in message
news:444180BBDD589C153EC7FEC3BF02D106@in.WebX.maYIadrTaRb...
> rw
Sean),
> > oAssyDoc.Update
> > oAssyDoc.Save
> > oAssyDoc.Close
> > End Sub
need
> > Thanks,
> > -af
Well .. After some keyboard damage I figured it out ..
I need to have Inventor running in the backgound.
I guess the bigger question is: How do I launch inventor -
Inventor.Application.Visible(False)
from my program that is the only thing running? so that when I save it says
ok to the dialog box?
news:816DD4544D5A0C49EE3C8865221C51C2@in.WebX.maYIadrTaRb...
> I input the code:
> oAssyDoc.Update
> oAssyDoc.Save
> oAssyDoc.Close
> End Sub
> I am using:
> OLE Automation
Replace
> > rw
issue,
> Sean),
the
> > > Set oAssyDoc =
> > > oAssyDoc.Update
> > > oAssyDoc.Save
> > > oAssyDoc.Close
> > > End Sub
> need
the
> > > Thanks,
> > > -af
If I am following correctly you need to set the SilentOperation property.
Also I think you are looking for the CreateObject function.
Kent
Assistant Moderator
Autodesk Discussion Forum Moderator Program
news:DE7FDA1075FC2E7032C2BBE3774BA038@in.WebX.maYIadrTaRb...
