Method to add the InsertConstrain... Where is the bug?
0 REPLIES 0
Message 1 of 1
chaiy
162 Views, 0 Replies
I tried to use some function with VC++ to select 2 Circular Edges and make insert Contrain them together.I have made a code but it has some mistake.It is not work.If some one kwon,Please help me.
best regrads,
  • Document* aDoc;
    // Chaeck Assembly's Document
    HRESULT Result = NOERROR;
    Result = m_Application->get_ActiveDocument(&aDoc);
    if (FAILED(Result) || !aDoc)
    BSTR stTempFile;
    CComVariant MyDocSubType(L"SubType");
    m_Application->GetTemplateFile(kAssemblyDocumentObject, kDefaultSystemOfMeasure,
    kDefault_DraftingStandard, MyDocSubType, &stTempFile);
    aDoc->Release();
    aDoc = NULL;
    Documents* aDocs = m_Application->GetDocuments();
    aDocs->Add(kAssemblyDocumentObject, stTempFile, TRUE, &aDoc);//erzeugt Absturz
    CWnd::GetActiveWindow()->MessageBox("punkt drei", "Wegpunkt", MB_OK|MB_ICONERROR);
    // Result = m_Application->get_ActiveEditObject(&aActObj);
    // if (FAILED(Result) || !aActObj)
    // return;
    CComQIPtr<AssemblyDocument> aAsmDoc(aDoc);
    CComQIPtr<AssemblyComponentDefinition> aAsmComDef;
    Result = aAsmDoc->get_ComponentDefinition(&aAsmComDef);
    InteractionEventsObject* oInteractEvents;
    SelectEventsObject* oSelectEvents;
    bool checkSelected = false;
    Result = m_Application->CommandManager->CreateInteractionEvents(&oInteractEvents);
    Result = oInteractEvents->put_SelectionActive(true);
    oSelectEvents = oInteractEvents->GetSelectEvents();
    Result = oSelectEvents->AddSelectionFilter(filter);
    Result = oInteractEvents->Start();
    int edge_Num = 0;
    int SelectCount = 0;
    CComQIPtr<Edge> aEdge[2];
    CComPtr<ObjectsEnumerator> oSelectedEnts ;
    AfxMessageBox("in Pick 2");
    Result = oSelectEvents->get_SelectedEntities(&oSelectedEnts);
    while(!checkSelected)
    // SelectCount = oSelectedEnts->GetCount();
    if (oSelectedEnts->GetCount() > 2)
    checkSelected = true;
    edge_Num++;
    aEdge[0] = oSelectedEnts->GetItem(1);
    aEdge[1] = oSelectedEnts->GetItem(2);
    CComPtr<InsertConstraint> aInsert;
    CComVariant Distance=0.0,
    BiasPointOne = 0.0,
    BiasPointTwo = 0.0;
    aInsert=aAsmComDef->Constraints->MethodAddInsertConstraint(aEdge[0],aEdge[1],true,Distance
    ,BiasPointOne,BiasPointTwo);
    0 REPLIES 0
