i Search here many for barcodes and find many but always i find is not the rigth 😞
when a Barcode font as TTF as Example "FREE3OF9.TTF" and export it via API or Export PDF Function
the Barcode on TextBlock dosent see it in PDF or it dosent work!
is ther any Working Solution to create a PDF with the build in PDF Exporter of Inventor?
Info:
i create many PDF with the API function so i dosent can have a PDF printer to create a Document
thx for Info or Tips
Mario
Inventor 2014
Solved by adam.nagy. Go to Solution.
Hi Mario,
I guess this is what you too run into - that the gaps are too big in the exported PDF (and the lines are not long enough):
I've just logged today some issue (id 1516273) concerning PDF export with a certain TrueType font. Not sure if the issue is the same here, but I made a comment about it in the change-request.
Unfortunately, either you need to find some way of creating the barcode with geometry, or create the PDF in some other way. Someone on the forum says that e.g. bullzip could be a solution. I've never used it so cannot comment on it:
http://forums.autodesk.com/t5/Inventor-General/Adding-Barcode-to-a-drawing/td-p/2663065
Sorry for the inconvenience 😞
Cheers,
Hey,
i create all pdf with a automatic via vault jobprocessor
and i dosent become messsage back wehn i create pdf with a pdf printer
when something works wrong!
with a pdf printer i can only look is a pdf create now on a place or not
i have found now this and i developing now a addin for inventor
http://www.codeproject.com/Articles/6968/Draw-EAN-barcode-lines-and-save-image-file-with-AS
to insert some diffrent barcode then on a drawing
thx mario
