Hello All,
We have developed custom C#.NET Addin on Visual Studio 2005 and trying to deploy/distribute onto other machines.
However, the InventorTCAddin add-in shown in attached image, doesn't get load.
A bit inconsistent behavior is observed for .NET Add-in and the same was found on ADN Forums. However, not able to resolve it.
All machines are having similar configuration with respect to OS and other applications.We also tried registering the add-in using regasm.exe, still the result is same. However, it was mentioned that 2012 developed addins are register-free. Please correct me if I've wrongly understood.
We'd like to understand the correct way of distributing the addin to other machines (32-bit and 64-bit Windows machines.)
It'd be great if someone from Inventor API Team can really help us.
Inventor version : Autodesk Inventor Professional 2012
Development IDE: Microsoft Visual Studio 2005
Inventor Addin : C#.NET
OS: Windows 7 - 32 bit.
Microsoft .NET Framework Versions available: Following different .NET flavors installed on the machine.
Inventor.exe.config file contents :
<!-- Since Inventor 2012 is an unmanaged application that's built against .NET 3.5,
we need to explicitly identify the framework version to use.
Otherwise, it will pick up the latest version that's been installed.
<startup>
<supportedRuntime version="v2.0.50727"/>
</startup>
Thanks & Regards,
Jayateertha.
