How do I get Color Override to iProperty? See attached
6 REPLIES 6
mortenrisumhansen7822
834 Views, 6 Replies
Hello Fellow Inventors!
My first post. New to iLogic (which is what I believe is the key to solve my request)
My company manufacturs many sheet metal parts that ends up being painted.
We need to describe both material and surface treatment in the title blocks on our idw's. Inventor parts then have a selected material (the required steel type) and a color override is applied (the required paint job)
But color override is not just like that to retrieve for the title block, like standard iproperties like <MATERIAL> or <THICKNESS>
See attached image for deeper understanding of my request for a solution.
How do I solve this issue? I believe it must be a well known issue for many companies..
Best Regards
Morten
6 REPLIES 6
in reply to: mortenrisumhansen7822
Sub RetrieveColor()
    If ThisApplication.ActiveDocumentType <> Inventor.DocumentTypeEnum.kDrawingDocumentObject Then Exit Sub
    Dim oDoc As Inventor.DrawingDocument
    Set oDoc = ThisApplication.ActiveDocument
    Dim oPropSets As Inventor.PropertySets
    Set oPropSets = oDoc.PropertySets
    Dim oPropSet As Inventor.PropertySet
    Set oPropSet = oPropSets.Item("Inventor Summary Information")
    Dim oProp As Inventor.Property
    Set oProp = oPropSet.Item("Comments")
    Dim oRefDoc As Inventor.Document
    Set oRefDoc = oDoc.ReferencedDocuments.Item(1)
    If oRefDoc.DocumentType <> Inventor.DocumentTypeEnum.kPartDocumentObject Then Exit Sub
    oProp.Value = oRefDoc.ActiveRenderStyle.Name
End Sub
Hi Robert
Thank you for your reply!
I was under the impression that one was notified by mail, if a reply was made to ones post. I visited the forum to check - and YES a reply :o)
Well, I am trying your code. I get a bunch of errors I am trying to grasp. 'Let' and 'Set' sentences is not supported anymore
I use Inv 2012
Am I missing anything?
I try to look further on..
Best regards
Morten
Ok we're closing in:
Sub Main()
RetrieveColor()
End Sub
Public Sub RetrieveColor()
Dim oDoc As Inventor.Document
If Not ThisApplication.ActiveDocumentType = Inventor.DocumentTypeEnum.kPartDocumentObject Or ThisApplication.ActiveDocumentType = Inventor.DocumentTypeEnum.kAssemblyDocumentObject Then Exit Sub
oProp.Value = oDoc.ActiveRenderStyle.Name
End Sub
I guess I didn't read your post correctly - somehow I missed that you were working in iLogic and that you were planning to run this with .ipts and .iams, not drawings.
The code I provided was to take the color overides from a referenced part and place it into the comments of the drawing.  It was written in VBA.
MegaJerk
If you wanted to go through an entire assembly you could use this code :
Dim openDoc As Inventor.Document
Dim docFile As Inventor.Document
openDoc = ThisDoc.Document
If openDoc.DocumentType = kAssemblyDocumentObject Then
	For Each docFile In openDoc.AllReferencedDocuments
		iProperties.Value(docFile.DisplayName, _
		"Summary", "Comments") = docFile.ActiveRenderStyle.Name
	Next
End If
If you just wanted to do this for one part then something like -
iProperties.Value("Summary", "Comments") = _
ThisApplication.ActiveDocument.ActiveRenderStyle.Name
 would work.
If my solution worked or helped you out, please don't forget to hit the kudos button 🙂
iLogicCode Injector: goo.gl/uTT1IB
GitHub
Hi Roger
Thanks a lot for all the great feedback - I will check your input asap and return with result!
Best regards
Morten
