Inventor Customization
ADN Support Specialist
xiaodong.liang
Message 11 of 14 (275 Views)
Re: Ilogic drawing view label scale and name
12-18-2012 12:07 AM in reply to: sergelachance
Sorry, I was very busy on DevDays.
I struggled to reproduce your problem, however it is hard without reproducible sample. Could you provide a small source code? In addition, have you debugged to check the error message is due to the line of GetPreciseStringFromValue. Or could you create a smallest test function to run UnitsOfMeasure.GetPreciseStringFromValue(oView.Scale,kInchLengthUnits) only to see if it works?
Xiaodong Liang
Developer Technical Services
Autodesk Developer Network
Distinguished Contributor
Message 12 of 14 (249 Views)
02-01-2013 03:19 AM in reply to: xiaodong.liang
THE FILE!
SORRY REALLY REALLY BUSY TOO :smileyhappy:
IT'S REALLY NECESSARY TO DELETE AND INSERT THE TITLEBLOCK???
THANKS AGAIN FOR YOUR HELP :smileyhappy:
Active Contributor
Message 13 of 14 (222 Views)
02-05-2013 02:44 AM in reply to: sergelachance
You should change like below. It works for me under 2013 @ win 7 -32bit.
sPromptStrings(0) = "SCALE " & oDoc.UnitsOfMeasure.GetPreciseStringFromValue(oView.Scale,UnitsTypeEnum.kInchLengthUnits)
 But it adds an "In" at the end and looks strange.
Be aware, the scale value itself is UNIT-LESS. If you write like A:B, it is fine. You can convert A and B seperately.
If it is only a ratio value, there is no point to have a conversion.
Regards
Peter
Message 14 of 14 (109 Views)
11-06-2013 11:20 AM in reply to: shirazbj
the solution who work for me is
  sPromptStrings(0) = "SCALE " & oView.ScaleString 'set to view scale
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
