I've posted a sample Add-In that demonstrates adding to the context menu in
autodesk.inventor.customer-files. It adds a new command to the context menu
whenever a face has been selected. The new command will display the area of
the selected face.
For some reason, I'm only able to insert the button at the bottom of the
context menu. I've filed a change request for this issue.
Brian Ekins
Developer Technical Services, Autodesk
Discussion Q&A: http://www.autodesk.com/discussion
"Kent Keller" wrote in message
news:B1434B4C6B9DA5F1A96C29B915A53BAC@in.WebX.maYIadrTaRb...
> Suppose it could just be that "How To" is just broken normally in that
state.
> I posted the method I used back on June 10th under the subject "A few
outstanding
> questions"
> If I am doing it wrong I would love to hear how to do it right 8^)
> Kent
> Assistant Moderator
> Autodesk Discussion Forum Moderator Program
> "Brian Ekins (Autodesk)" wrote in
message
> news:5A00A6F21C57D87C7EB6345773400B1A@in.WebX.maYIadrTaRb...
> > I just tested it and it's working ok for me. There must be something
> > specific that you're doing or the "How To" is broken at the state you
have
> > Inventor in.
> > Brian Ekins
