Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Add a Property
2 REPLIES 2
179 Views, 2 Replies
Add a Property
I have a PropertySet set up. I am wanting to check them by name, and if
they do not exist, add them. The code is below. At the ninth and tenth
lines below, how can I add the properties back in?
Thanks for the help....
Private Sub ChkUserProp()
Dim oPropNew As Property
' Use existing oProp4 to add properties if they do not exist (oProp4 has
not been initially defined in other sub)
Set oProp4 =
ThisApplication.ActiveDocument.PropertySets("{D5CDD505-2E9C-101B-9397-08002B
2CF9AE}")
' Delete Properties Example
For Each oPropNew In oProp4
oProp4(1).Delete
Next
' Re-add Properties Example ???
Call oProp4(1).Add("Test", "Finish")
' If oPropNew.Name <> "Finish" Then
' Call oPropNew.Add("Test", "Finish", 1)
' End If
' If oProp4.ItemByPropId.Value <> "MAT'L CODE" Then
' oProp4(2).Add "MAT'L CODE"
' End If
' If oProp4.ItemByPropId.Value <> "MATERIAL" Then
' oProp4(3).Add "MATERIAL"
' End If
' If oProp4.ItemByPropId.Value <> "SUB NO." Then
' oProp4(4).Add "SUB NO."
' End If
' If oProp4.ItemByPropId.Value <> "MFG CODE" Then
' oProp4(5).Add "MFG CODE"
' End If
' If oProp4.ItemByPropId.Value <> "RSP" Then
' oProp4(6).Add "RSP"
' End If
End Sub
2 REPLIES 2
I figured out how to add the properties. The problem is that they default
to "TEXT" fot type. How is this information changed to the other types?
Such as Yes No?
Set oProp4 =
2CF9AE}")
oProp4(1).Delete
Next
Set oPropNew = oProp4.Add("", "Finish")
Set oPropNew = oProp4.Add("", "MAT'L CODE")
Set oPropNew = oProp4.Add("", "MATERIAL")
Set oPropNew = oProp4.Add("", "SUB NO.")
Set oPropNew = oProp4.Add("", "MFG CODE")
Set oPropNew = oProp4.Add("", "RSP")
"Steve Anderson" wrote in message
news:47F79050684E2B8E55BCD7D9A83D2F25@in.WebX.maYIadrTaRb...
has
> Set oProp4 =
> 2CF9AE}")
> oProp4(1).Delete
> Next
> ' End If
> ' End If
> ' End If
> ' End If
> ' End If
> ' End If
> End Sub
The values of properties are actually Variants which means it can represent
many different types. You define the type implicitly by the type of input
value used in the assignment. Here's a modified version of the portion of
your code where you're creating the properties. The "Finish" property will
be a Yes/No since I'm setting it using a Boolean value. The "Sub No." will
be a number because I'm setting it with a number. I could also use a
variable that is Integer, Long, or Double type to create a number property.
The "RSP" property will be a date because it is set using a date value.
Set oPropNew = oProp4.Add(True, "Finish")
Set oPropNew = oProp4.Add(0, "SUB NO.")
Set oPropNew = oProp4.Add(Now, "RSP")
Brian Ekins
Developer Technical Services, Autodesk
Discussion Q&A: http://www.autodesk.com/discussion
news:5DFEECFA0F26CB1364C2D6A7F9AC9572@in.WebX.maYIadrTaRb...
> Such as Yes No?
has
> Set oProp4 =
> 2CF9AE}")
> oProp4(1).Delete
> Next
> has
> > Set oProp4 =
> > 2CF9AE}")
> > oProp4(1).Delete
> > Next
> > ' End If
> > ' End If
> > ' End If
> > ' End If
> > ' End If
> > ' End If
> > End Sub
