Installation & Licensing
unexpected exit on file open and no communication center connection
10 REPLIES 10
Message 1 of 11
cvbt-thailand
908 Views, 10 Replies
IV crashes when I open a file (or try to create a new file).  AutoCAD does not.  Both products always show (when selecting the communications center):
"The Communication Center Cannot be accessed due to a problem with your internet connection or with an AutoDesk server"
before IV crashes.  If IV starts and the Communication Center can be accessed then IV will not crash on file open.  The problem usually goes away if I reboot my computer.  I have installed DL17369034 and DL18361047 hotfixes related to file fails to open or unexpect exit on file open.
Geoffrey Wheeler
AutoCAD Mechanical 2011 SP2, IV Pro 2011 64bit SP2, stand alone, Design Review 2018, DWG True View 2018, Inventor View // Win7 Ultimate SP1
ASUS P8H61-M LE, Intel i5-3450 @ 3.10 GHz, 8GB RAM // ATI AMD Radeon HD 6600 Series, 1GB RAM
10 REPLIES 10
Message 2 of 11
TravisNave
in reply to: cvbt-thailand
In my experience, Inventor crashing on File > Open is most often video card related.  What version of Inventor are you running and what is your Video Card / Driver version?
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Message 3 of 11
cvbt-thailand
in reply to: TravisNave
Hi! Thanks for the tip.  Here are my spec's
IV Pro 2011 64bit SP2; Win7 Ultimate SP1
ASUS MB Intel i5-3450 @ 3.10 GHz, 8GB RAM
Onboard Intel HD Graphics Driver Ver. 9.17.10.2932
I recently updated the driver.  I think I had the problem even before I updated the driver.
Geoffrey Wheeler
Message 4 of 11
TravisNave
It's almost certainly your video card.  Inventor requires a more sophisticated video card, rather than an onboard shared video.  You might be able to go into your applications options and turn off everything.  Go out and buy a decent video card thats on the approved video card list.  That should get you going.
Autodesk Forums:
Message 5 of 11
cvbt-thailand
Thanks Travis Nave,
I switched to my other graphics card on the same computer:
My driver checks as being up-to-date.
I still have the problem.
Why would it crash if I the communication center is unaccessible?  If I can solve that problem maybe the file open crash will stop.
Geoffrey Wheeler
Message 6 of 11
I find that before the file open crash happens the search bar will also error.
I tried to disable the communication center using a reg edit.  The edits had no affect.  The com ctr works when it works and when it doesn't, IV crashes on file open.  If I could solve the comm ctr problem maybe the file open / crash problem would be solved as well.
Geoffrey Wheeler
Message 7 of 11
TravisNave
You might try this hotfix:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=18361047&linkID=9242019
Also, your Radeon card is not certified for Inventor 2011.  It still could pose a problem.
Autodesk Forums:
Message 8 of 11
cvbt-thailand
Thanks.  I have installed that hot fix as well as another (see my initial post).
My AMD Radeon 6600 supports  Open GL 4.1  A new graphics card is a large investment for me.
My work-around right now is to reboot my computer.  This usually clears the problem.
Is there any OS settings or software that could be affecting this?
Here are my hardware diagnostics:
This Direct3D graphics driver is Microsoft WHQL certified
Graphics Hardware Description:
ATI Technologies Inc. ATI display adapter (0x6758)
AIRViz Device Manager \ VirtualDeviceDx10
Feature Level 4_0
Hardware Renderer
Graphics driver file aticfx64.dll,aticfx64.dll,aticfx64.dll,aticfx32,aticfx32,aticfx32,atiumd64.dll,atidxx64.dll,atidxx64.dll,atiumdag,atidxx32,atidxx32,atiumdva,atiumd6a.cap,atitmm64.dll is version 8.861.0.0
Current optimization settings are not known
The display is using 32-bit color
Inventor Version:
Build: 309, Release: 2011 SP2 - Date: Thu 04/28/2011
64-Bit Edition - 8192.00 GB
Loaded Inventor Add-Ins:
Routed Systems: Tube & Pipe
Assembly Bonus Tools
iLogic
Simulation: Dynamic Simulation
Autodesk Mold Design
Simulation: Frame Analysis
Content Center
Inventor Studio
Design Accelerator
EDM Addin
Frame Generator
AEC Exchange
Routed Systems: Cable & Harness
iCopy
Content Center Item Translator
Drag & Drop Interoperability
Simulation: Stress Analysis
Autodesk DWF Markup Manager
System Information:
Operating System:         64-bit Microsoft Windows 7 Ultimate  (Build 7601) Service Pack 1
Language:             English
System Manufacturer:         System manufacturer
System Model:             System Product Name
BIOS:                 BIOS Date: 05/11/12 14:05:02 Ver: 41.04
Processor:             Intel(R) Core(TM) i5-3450 CPU @ 3.10GHz (1 processor, 4 cores)
System Memory:             7.714 GB RAM
Graphics Device Information:
Renderer:             HAL
Manufacturer:             ATI Technologies Inc.
Chip Type:             ATI display adapter (0x6758)
DAC Type:             Internal DAC(400MHz)
Graphics HW Memory:         1024 MB
Display Mode:             1024 x 768 (32 bit) (85 Hz)
Graphics driver file:         aticfx64.dll,aticfx64.dll,aticfx64.dll,aticfx32,aticfx32,aticfx32,atiumd64.dll,atidxx64.dll,atidxx64.dll,atiumdag,atidxx32,atidxx32,atiumdva,atiumd6a.cap,atitmm64.dll
Driver file version:         8.861.0.0
Driver Date:             24 May 2011 0:00:00 UTC (Coordinated Universal Time)
Direct3D Graphics Device Information:
Adapter Description:         AMD Radeon HD 6600 Series
Vendor ID string:         0x00001002
Device ID string:         0x00006758
VendorID:             1002
DeviceID:             6758
SubSystemID:             23091787
Revision:             0
Direct3D 10 / DXGI System Information:
Dedicated Video Memory:     1009 MB
Dedicated System Memory:     0 MB
Shared System Memory:         3.607 GB
DxDiag System Information:
Operating System:         Windows 7 Ultimate 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.130318-1533)
Language:             English (Regional Setting: English)
Processor:             Intel(R) Core(TM) i5-3450 CPU @ 3.10GHz (4 CPUs), ~3.1GHz
System Memory:             8192MB RAM
Page File:             2443MB used, 5453MB available
DirectX Version:         DirectX 11
DxDiag Version:         6.01.7601.17514
DxDiag Graphics Device Information:
DirectX Version:         10.0
DDI Version:             11
DDI Version Number:         b
DxDiag WHQL Level:         0
Driver Signed Valid:         True
Driver Signed:             True
Revision:
Graphics HW Memory:         606 MB
Display Mode:             1920 x 1080 (32 bit) (60Hz)
Driver file version:         8.17.0010.1083
Driver Date:             5/25/2011 10:06:38
WHQL Level:             1
Inventor Options Information:
Options = 0x00000000
Warning Options = 0x00000000
Graphics driver log information:
Geoffrey Wheeler
Message 9 of 11
Is there any way to test if it is the video card without buying a new one.  This is an intermittent problem.  It happens once every week or so.
Geoffrey Wheeler
Message 10 of 11
TravisNave
I have a sign on my desk that reads, "ATI = Always Trashes Inventor."
I suspect the video card.
Autodesk Forums:
Message 11 of 11
This may not apply to an intermittent issue. However, below are some suggestions you may want to look at.
One setting you may need to verify is located in Control Panel\All Control Panel Items\Display.
  • Verify that you have your settings set to 100%.
  • Also, check that the Set Custom Text (DPI) settings are set to 100%.
You may consider modifying the settings in the Hardware tab of the Application Options. Will Inventor open a workspace while in Compatibilty mode or with Software graphics enabled?
You may find other suggestion to maximize performance in Inventor (and Windows) in the below link.
http://knowledge.autodesk.com/support/inventor-products/troubleshooting/caas/sfdcarticles/sfdcarticl...
Last, you may also want to verify that this is not a conflict with your anti-virus software. Do you have exceptions created in your anti-virus software for Autodesk Inventor?
Nathan Chandler
Principal Specialist
Administrator Productivity
