Installation & Licensing
to install client machine
2 REPLIES 2
kcet.skret
328 Views, 2 Replies
sir i have installed license machine ,till now i cant able to install client machine for autocad ,inventor please guide me
2 REPLIES 2
aaronhai
in reply to: kcet.skret
Hi kcet.skret,
(1) Please refer to the below document for License Server setup.
Refer - How to Configure your Network License Server
(2) For client setup, you should install the product by selecting Network Option for the installation process. You will be prompted to key in or point to the License Server during the install process.
(3) Upon completion, simply add the Server Hostname in the Systems Environment Variable.
Refer - How to specify license servers using the ADSKFLEX_LICENSE_FILE environment variable
(4) You should be able to launch the product now.
Other Autodesk Licensing Reference Links:
- Setting up Your Network License
- Network Licensing Guide
Please let u sknow if you need further assistance. Thank you.
Aaron Hai
TravisNave
Please post your installation logs for the failed client installs.
Autodesk Forums:
Administrator Productivity
