Installation & Licensing
New Member
Message 1 of 4 (114 Views)
server crash
114 Views, 3 Replies
12-01-2005 06:27 PM
I have been told that there is a script file that can be run on a networked autocad station to make it believe it is a 30 day stand alone trial version. That gives the firm time to fix the server but keep everyone working.
Has anyone ever heard or tried this?
*Sam Hochberg
Message 2 of 4 (114 Views)
Re: server crash
12-02-2005 08:42 AM in reply to: rklann1
You can simply "check out" the license for that time period (or longer,
depending on version), under your Tools pulldown you should see a "License
Borrowing" option....
Sam Hochberg
Inventor Certified Expert
Not too bad at AutoCAD either
wrote in message news:5027360@discussion.autodesk.com...
*Sam Hochberg
Message 3 of 4 (114 Views)
Re: server crash
12-02-2005 08:44 AM in reply to: rklann1
Oh, I see, your server is already dead? Never mind....
Sam Hochberg
"Sam Hochberg" wrote in message
news:5027846@discussion.autodesk.com...
Sam Hochberg
*Expert Elite*
TravisNave
Message 4 of 4 (114 Views)
Re: server crash
12-08-2005 10:16 AM in reply to: rklann1
Yes,
I have a post that explains that process here in the forum...
Here is the summary:
You need to modify a key in the registry that tells AutoCAD if it is a network version or a stand-alone version. The registry key is located in:
HKLM \ Software \ Autodesk \ AutoCAD \ R16.x \ ACAD-400x:xxx \ AdLM
You want to modify the value of the REG_DWORD Type to:
19 = Network (25-decimal)
2a = Stand-alone (42-decimal)
The values are in hexidecimal.
When you start AutoCAD again, it will ask you if you want to run as a 30-day or Authorize your stand-alone copy. You can't authorize it, so run as a 30-day. This will only work if it has never run as a 30-day. Also, once this process has been done and you've expired the trial, it can never be done again on that computer.
Travis Nave Send TravisNave a Private Message                       Need help in your post? Mention me with @TravisNave
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Connect with Us
Twitter
Pinterest
Blog
Youtube
