Mick
this is usually due to the failed language pack installation.
If you can post the Log file. (%temp% folder) for the installation, it might give us some clue on why the language pack install fails.
hi,
im having the exact same problem with autocad2011 installation.
but i cant seem to find the %temp% folder file. where can i find this?
olivia
Start ->Run->
type %temp%
click OK
this should take you to the temp folder
thank you, i've successfully reached the temp folder.
which file name will tell me why this happened?
AutoCAD 2011 Setup
Olivia
attached are my temp log files.
why has this error happened?
many thanks,
olivia
This is a very generic error (1603) without detailed log about where it fails it is difficult to troubleshoot
You should find more log files about each of the failed component. Meanwhile please the MS KB related to this error
http://support.microsoft.com/kb/834484
I NEED SOLUTION TO THIS PROBLEM PLEASE SAY HOW TO RECTIFY MY PROBLEM SIR
