Installation & Licensing
"Unknown video card" in Revit 2013 x64 with NVIDIA Quadro K3000M video card
8 REPLIES 8
Message 1 of 9
4502 Views, 8 Replies
I've been reading about similar problems in other posts however my problem is that when I actually use the link (http://usa.autodesk.com/adsk/servlet/syscert?siteID=123112&id=18844534) in Revit to update my driver and I punch in all of my config settings (see attachment "step2.jpg"), I actually see my video card as a supported device for Revit 2013 (64-bit) in the list (see attachment "step4.jpg").
After I install the driver as instructed and go back into Revit 2013, I still see the same problem "Unknown video card".  Can anyone tell me why it would still say that when this video card is in fact approved for Revit 2013 and I've installed the recommended driver using the Autodesk Certified Hardware applet?
Rob
8 REPLIES 8
Message 2 of 9
DarrenP
is their an issue with the software besides that warning message?
DarrenP
Message 3 of 9
TravisNave
Right.  I wouldn't sweat it.  So long as you have a supported card and driver then you are set.  That dialog box is populated with an XML database that quite simply could be out of date.  Like Darren said, if you are not experiencing any issues, you are good to go.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Message 4 of 9
in reply to: TravisNave
We thought it might be this video card error that is causing a rendering problem/issue.  We have rendering set to the best setting and it appears to stop at about 12% even though the timer keeps going.  We get a black screen.  I am waiting to receive a screen shot of what it is doing but in the meantime, I figured I would post this as is.  Do you think this issue has anything to do with the "unknown video card" indicator or would it be related to something completely different?
Rob
Message 5 of 9
DarrenP
rendering (mental ray) in revit doesn't use the video card only cpu and RAM
DarrenP
Message 6 of 9
Older video card driver warning message is appearing in Revit 2013 and 2014. The dialog on both versions say current driver: 2.0.200.0 and the certified driver is : 9.18.13.745. I have updated the video card driver for both machines but the warning stays the same. You mention an XML file that holds this information. Is it possible to edit the XML file?
Tags (2)
Message 7 of 9
galloherbertarchitects
I have the same problem with a video card geforce GTX750 w/ 2gb of ram, ASUS Rampage IV Black Edition  mother board, I7 6 core 4930K with 32 gb of memory ...
it goes to 10% and goes black......  i think i have plenty of ram (32gb) so i dont think is the CPU.... when rendering does it use all 6 cores or just one ??
thanks
Dan
Message 8 of 9
thanks
Dan
Message 9 of 9
in reply to: galloherbertarchitects
hi guys
i have a problem with revit..... when i press on material icon or this icon " (...)" nothing happens no windows open or anything
i uninstalled it and installed again... still the same.... i tryed revit 2014 2015 and 2016 and still the same... what can be the problem
PLUS.... i have this "unknown video card" aswell
so do you think it's related ??\
thanks
Administrator Productivity
