Installation & Licensing
Product Support
Message 1 of 11 (15,614 Views)
pit.config is not found Windows Autocad LT 2011
15614 Views, 10 Replies
06-18-2010 03:52 AM
Recently we had an issue with Autocad LT 2011 installation on Windows 7 . Installation went successfully, but on startup of the program EULA Window was shown up again and on entering the serial number(OR choosing the Trial mode) following Error message was shown
"pit.config is not found"
We fixed it by doing the following Registry change
Changed the value to 00000001 from 00000000
[HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk\AutoCAD LT 2011 - English]
"Eula"=dword:00000001
How to Edit the Registry
http://usa.autodesk.com/getdoc/id=TS66513
Result.
EULA window was not shown on startup of Autocad LT anymore; hence no more pit.config error. subsequently we could activate the program normally.
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
For more tips & tricks: http://upandready.typepad.com
Hashim Mundol
Autodesk Product Support
Member
Paul_GISkit
Message 2 of 11 (15,077 Views)
Re: pit.config is not found Windows Autocad LT 2011
08-26-2010 01:44 AM in reply to: hashim.mundol
I had the same problem with the installation op AutoCadMap3D 2011 on my pc (on my laptop, however, I had no problem at all). The solution provided worked perfect (changing the key: HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk\AutoCAD Map 3D 2011)! Thanks!
New Member
gvez
Message 3 of 11 (14,209 Views)
10-27-2010 02:38 AM in reply to: hashim.mundol
It is very nice that the problem can be solved but it would be great if i could have more analytical instructions about where to go and what to change exactly. As it is obvious i have the same problem for a long time and now finally that there is a solution i cannot quite understand what i should do. Sorry for the incovenience
Product Support
Message 4 of 11 (14,206 Views)
10-27-2010 02:44 AM in reply to: gvez
I have added the link on how to edit the registry.
Hashim Mundol
New Member
jms_snw92
Message 5 of 11 (8,894 Views)
03-29-2011 06:29 AM in reply to: hashim.mundol
Hi, after i follow the step that you are given it still have some error reading the file after saving to my desktop. ( cant be read inside the content that are saved to change the code . May I know what should i do now please ? thanks !  =)
:smileyhappy:
Member
HACCarter
Message 6 of 11 (7,485 Views)
06-14-2011 04:05 PM in reply to: hashim.mundol
I had this problem too when I installed Autocad lt 2011 on virtual windows 7 run using vmfusion on a macbook pro.  I followed instructions given changeing the regestry to 00000001 and the EULA window no longer appeared.  The autocad startup window came up and then just dissappeared and it will not open. Any suggestions?
Product Support
Message 7 of 11 (7,479 Views)
06-14-2011 11:43 PM in reply to: HACCarter
Please post the adlm log
c:\programdata\autodesk\adlm\*adlm*.log
Hashim Mundol
Member
HACCarter
Message 8 of 11 (7,466 Views)
06-15-2011 04:59 AM in reply to: hashim.mundol
adlm.log attached
Product Support
Message 9 of 11 (7,461 Views)
06-15-2011 06:14 AM in reply to: HACCarter
seems to be corrupt license, did you have any other Autodesk software activated on this machine ?
you could try a clean uninstall and reinstall of Autocad, if it fails, we might have to clean the license files manually
Hashim Mundol
Member
HACCarter
Message 10 of 11 (7,456 Views)
06-15-2011 07:00 AM in reply to: hashim.mundol
I had a trial of Autocad lt 2012 before I had the licence for the 2011.  I did uninstall and reinstall 2011 before i found the solution for the pit.config problem.  However, material library and design review etc. were left on the computer.
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Ask the Community
Connect with Us
Twitter
Pinterest
Blog
Youtube
