If the solution linked below doesnt help, try renaming the following
registry key (start > run > regedit)
HKEY_CURRENT_USER\Software\Autodesk\R16.0\ACADxxx:xxx.
AutoCAD will re-create that section it the next time you start the program.
It should correct the problem. You have to do this once for each user
having trouble.
If you browse through that section, you will more than likely see paths
listed that do not match the current %USERPROFILE% windows environment
variable.
It may be:
c:\documents and settings\fred
vs.
c:\documents and settings\fred.domain (or fred.001)
Chris
"Luis Andueza" wrote in message
news:4822308@discussion.autodesk.com...
> Autocad 2004,
> Windows 2000,
> each machine has an installation of autocad,
> and the users are in a PDC server.
> The problem is that the local accounts open, but the mobile profiles do
> not open, this estarted to happend after a PDC server actualization.
> Thanks
> TravisNave wrote:
>> Might help if you listed your version of AutoCAD, the type of install,
>> and the Operating System.
>> http://usa.autodesk.com/adsk/servlet/ps/item?siteID=123112&id=3502566&linkID=2475323
