We are trying to install the network license server for the Building Design Suite on a Debian Linux server. On serverside everything seems to be working, but the clients can't connect to the server.
Has anyone successfully installed the license server on Linux?
Is there a way to troubleshoot al Linux license server?
Is there any documentation on configuring the server on Linux?
Solved by modulo_architects. Go to Solution.
Welcome to the community.
Do you actually have a working adskflex vendor for Linux?
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=16273721&linkID=9242819
Yes, we hava a working vendor. This is the content of the log:
15:58:33 (lmgrd) The license server manager (lmgrd) running as root: 15:58:33 (lmgrd) This is a potential security problem 15:58:33 (lmgrd) and is not recommended. 15:58:33 (lmgrd) FLEXnet Licensing (v11.7.0.0 build 73797 x64_lsb) started on fileserver (linux) 15:58:33 (lmgrd) Copyright (c) 1988-2009 Acresso Software Inc. All Rights Reserved. 15:58:33 (lmgrd) US Patents 5,390,297 and 5,671,412. 15:58:33 (lmgrd) World Wide Web: http://www.acresso.com 15:58:33 (lmgrd) License file(s): acad.lic 15:58:33 (lmgrd) lmgrd tcp-port 27000 15:58:33 (lmgrd) Starting vendor daemons ... 15:58:33 (lmgrd) Using vendor daemon port 2080 specified in license file 15:58:33 (lmgrd) Started adskflex (internet tcp_port 2080 pid 31777) 15:58:33 (adskflex) Unable to initialize access to trusted storage: 2 15:58:33 (adskflex) FLEXnet Licensing version v11.7.0.1 build 79971 x64_lsb 15:58:34 (adskflex) Server started on fileserver for: 15:58:34 (adskflex) 65900REVITS_F (consisting of: 85623REVITS_2011_0F 15:58:34 (adskflex) 74200REVITS_2010_0F 60900REVITS_2009_0F 54700REVITS_2008_0F) 15:58:34 (adskflex) PLIST 15:58:34 (adskflex) EXTERNAL FILTERS are OFF 15:58:34 (lmgrd) adskflex using TCP-port 2080 17:06:34 (adskflex) TCP_NODELAY NOT enabled 21:58:33 (lmgrd) TIMESTAMP 8/2/2012 22:03:37 (adskflex) TIMESTAMP 8/2/2012 3:58:33 (lmgrd) TIMESTAMP 8/3/2012 4:08:40 (adskflex) TIMESTAMP 8/3/2012 9:58:33 (lmgrd) TIMESTAMP 8/3/2012 10:13:41 (adskflex) TIMESTAMP 8/3/2012 15:58:33 (lmgrd) TIMESTAMP 8/3/2012 16:18:42 (adskflex) TIMESTAMP 8/3/2012 18:25:46 (lmgrd) Rereading license file... Requested from root@fileserver 18:25:46 (lmgrd) Done rereading 18:25:46 (lmgrd) ...Finished rereading 18:25:47 (adskflex) Rereading license file... 18:25:47 (adskflex) Server started on fileserver for: 18:25:47 (adskflex) 65900REVITS_F (consisting of: 85623REVITS_2011_0F 18:25:47 (adskflex) 74200REVITS_2010_0F 60900REVITS_2009_0F 54700REVITS_2008_0F) 18:25:47 (adskflex) PLIST 18:25:47 (adskflex) Updating feature 65900REVITS_F
Yes, I can ping the fileserver on the network. I get an IP4 address in response. Netstat tells me that both port 2080 and 27000 are open and that these ports are linked tot adskflex and lmgrd.
Is there a way to check the available licenses in Linux?
I am sure there is some sort of lmutil syntax you can use to verify. However, your log file already shows there are products available.
What error are you getting at the client?
I don't realy get an error message when I try to connect from the client side:
First a get an window where I can enter the license server name
When I enter 'fileserver' I get the same window again.
This is strange because for any other servername I enter, I get the "could not obtain license error".
I found out that most of our PC's did connect to the new license server. It seemed to be a local problem on some PC's, including my own. I reinstalled the building design suite on the affected PC's and everything seems te be working fine now...
The problem is solved. Thanks very much for your help!
